Radikal Spectralis
Radikal Technologies Spectralis Groovebox / Sequencer
features
- Hybrid Synth with 4 OSCs & Moog style analog 24 dB LP Filter and 12 dB analog Multimode Filter (4 Filter Types)
- 192th resolution chase light sequencer that can handle independent Tracks (back & forth) and Trigger little "Track Envelopes" as a Modulation Source.
- Filterbank
- Samples 96MB
features - deutsch
- 192tel Auflösung des Lauflicht-Sequencers
- Hybrid Synthesizer mit Moog Filter Kaskade
- Filterbank
- Samples 96MB
Tips & Tricks
quick switch between 2 different OSC pages
you can switch directly between two OSC pages using the [OSC WAVE] & MACRO CTRL encoder
[OSC WAVE] memorizes the last selected page
[MACRO CTRL] memorizes any page between 10 and 26
Sometimes an Encoder memorizes two pages - needs further investigation and description
shorten a motif
press [MOTIF] and then display encoder [EDIT] <br> the following display page allows you to change the length & loop type of a motif
Init Sound
[SHIFT]+[SET ROUTING] intializes the H-Synth Part. <br> You don't hear anything afterwards, because alle TriggerGroups are cleared. Hold down [12/Analog Synth] while in Part Select Mode to enter the TriggerGroup Pages, then use the Page Keys to access the TriggerGroup assign Pages. Assign all Elements to TG1 for a normal H-Synth Sound.
How to use different FX Send Levels for MM Filter, LP Filter and Filterbank
Beside the H-Synth global FX1 Send accesible via [FX1-SEND] there are different FX1 Send controls for MM Filter, LP Filter and the Filterbank.
The Send for MM & LP Filter can be found in the [EG DEPTH] menu page 5&6. The Filterbank FX1 Send has a dedicated knob [FB>FX1/12].
Different FX Levels are usefull if you have multiple TriggerGroup, for example a dry LP Bass Sound, a MM Lead Sound with medium delay and a Filterbank with lots of delay.
LFOs have no effect
The the [MOD DEPTH] of the global LFOs must be > 0, because the mod depth is the master Level control for a global LFO.
The Voice/Filter LFOs only work as a mod source if their original Amount is > 0.
Example : You can only modulate TLM of OSC1 with the LP Filter LFO if the LP Filter LFO has a Mod Depth > 0
Display Reference
Analog Synth
VCO
via [OSC WAVE] or [MACRO CTRL]
Page 1/26 VCO Shape ^Osc1 ^Osc2 ^Osc3 ^Osc4
Oscillator Waveform Selection
0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle
1/2:VCO? WAVE ^Shape:255 ^Tlm:100 Sync:0 (Sync OSC1 only) Ring:off (Ring OSC4 only)
Tlm = Time Linearity Modulation kind of Pulse Width Modulation
Sync = Oscillator synchronisation adjustable between soft and hard sync
Ring = Ringmodulation
VCO ? Waveform Modulation Src1: Dpth1: Src2: Dpth2:
Waveform Modulation
Src1/2 : Modulation Source
Dpeth1/2 Modulation Depth
VCO ? Tlm Modulation Src1: Dpth1: Src2: Dpth2:
Time Linearity Modulation (Pulse with modulation for all waveforms)
2/2:VCO? WAVE O3PM:0 O4PM:0 O3FM:0 O4FM:0 Osc3 & 4 can be used for either PhaseModulation (like yamaha FM) or real FM
O3/4PM : Phase Modulation Amount (like Yamaha FM) by Oscillator 3 or 4
O3/4FM : Frequency Modulation Amount (traditional FM) by Oscillator 3 or 4
2/26:VCO EG ^Osc1 ^Osc2 ^Osc3 ^Osc4
Oscillator Envelope macro - adjust ADSR Envelope with just one dial
Subpages see Envelopes Section which contains all AnalogSynth Envelopes
3/26:VCO FB Volume Osc1-4
Filterbank Feed Level
4/26:VCO MM Volume Osc1-4
12dB Multimode Filter Feed Level
5/26:VCO LP Volume Osc1-4
24dB LP Filter Feed Level
6/26:VCO FX1 Send Osc1-4
FX1 Send for each Oscillator - use for fm sounds that don't use a filter
7/26:VCO Bus Volume Osc1-4
Bus Volume Level - dry osc signal level
use for fm sounds without filter
8/26:VCO Bus Panning Osc1-4
Bus Panning - adjusts the paning of the
9/26:VCO EG Bypass Osc1-4
Oscillator Envelope Bybass Level - set to max to deactivate VCO EG
10/26:VCO1 TLM TlmM:0 TlmF:VCO? WaveM:0 WaveF:VCO?
TlmM - TimeLinearityModulation Modulation Amount
TlmF - TimeLinearityModulation Source
WaveM - WaveformModulation Amount
WaveF - WaveForm Modulation Source
Page 11-13 contain the same settings for VCO2-4
14/26:VCO1 Div1 Sync:0 Glide:0 Pitch:A3 Scale:12
Sync (VCO1 only): Oscillator Synchronisation VCO 1 only
Ring (VCO 4 only): Ringmodulation between Osc 3 & 4 - Output replaces VCO4 Signal
Gilde : Glide Amount
Pitch : Pitch is the root key of the scale function. If you set the pitch to C3, the C3 of the keyboard will give you the original pitch - the keys above will react like set in the scale function and below the root in the opposite direction down.
Scale: By default, the scale is set to 12 - that means an octave has 12 halftones. Each halftone is a 1/12 octave step if set to 12. If you set the parameter to -12, each key to the right on your keyboard will have a 1/12 Octave lower pitch - so the keyboard is reversed then. (It is often fun to try a running sequencer line with one oscillator set to 12 and one to -12. Sometimes a coarse tuning together with a negative scale gives good sonic results.
But you can set the scale also to 1 - that means the next halftone will be reached if you press one octave up at the keyboard. If it is set to 0, the pitch will not be changed at all. Each note at the keyboard then has an equal pitch. You can use this feature for all oscillators independently. Its a good way for creating clusters and FX sounds - especially when the oscillators are modulating each other with FM or PM.
Pages 15-17 contain the same settings for VCO2-4
18/26:VCO1 Div2 Crush:0 Phs:0 FmDp:0 PMod:2
Crush : Bitcrusher Amount - creates distortion and alliazing
Phs : Start Phase 0 - free running Osc (like analog) , 1-100 fixed start phase for use with fm/pm sounds
Pages 19-21 contain the same settings for VCO2-4
22/26 Noise EG Feed FB:0 LP:0 MM:0 Bus:0
Noise Feed via Noise Envelope
FB : Noise to Filterbank
LP : Noise to Lowpass
MM : Noise to MultiMode Filter br>
Bus : Noise to Bus Amount
23/26 Noise Direct Feed FB:0 LP:0 MM:0 Bus:0
Direct Noise Feed - Trigger and Envelope independent
24/26 VCO Key->Level ^Osc?:0
1/4:VCO1 KSL Pitch:C-3 Pitch:C-3 Pitch:C-3 KsSc:12 - explanation needed
2-4 contain the same settings for VCO2-4
25/26 VCO Vel->Level Osc?:0
26/26 VCO Phase Osc?:0
Collection of all Osc Phase settings that can also be found on the VCO Div2 pages
via [OSC DETUNE]
1/4 VCO Fine ^Osc1 ^Osc2 ^Osc3 ^Osc4
Osc1-4 fine tune amount
1/12 VCO Fine Tune Modulation KeyPt:0 RndPt:0 VibSp:0
2/12 VCO Pitch LFO LWve:0 LRte:0 LDpt:0
3/12 VCO Pitch Modulation Src1: Dph1: Src2: Dph2:
4-12 contain the same settings for VCO2-4
2/4 VCO Coarse ^Osc?:0
VCO Pitch Envelope Preset ^Osc?:0
1/4:VCO1 Pitch StPt:0 Time:0 Time:0 EndP:0
3/4 VCO Key Scale Osc?:0 - collection of all VCO Key Scale settings that can also be found on the VCO Div1 pages
4/4 VCO0 Pitch Mod PMod:0 PMod:0 PMod:0 PMod:0 - collection of all VCO PMod settings that can also be found on the VCO Div2 pages
via [GLIDE]
VCO Glide Glide:0 Glide:0 Glide:0 Glide:0
TODO - OSC Section Picture, Knob & Button modes
LFO
via [LFO WAVE]
Master LFO Wave Menu ^LWve:0 ^LWve:0 ^LWve:0 ^LWve:0 - LFO Waveform 0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle, 255=S&H
1/4 Master LFO 1 Waveform Control LWve:0 LPhs:0
2-4 contain the same settings for LFO2-4
via [MOD DEPTH]
Master LFO Modulation Depth ^LDpt:0 ^LDpt:0 ^LDpt:0 ^LDpt:0
1/4 Master LFO 1 Depth Control LDpth:0 ^LEDp:0
1/4 LFO 1 Depth Control Envelope LEDl:0 LEAT:0 LERl:0 LEDp:0
via [MOD DEPTH]
Master LFO Rate Menu LRte:0 LRte:0 LRte:0 LRte:0
VCF
via [CUTOFF LP] or [RESO LP]
1/8 LP LFO FmWve:0 FmRte:0 FmDpt:0
2/8 LP LFO FmEDl:0 FmEDa:0 FmEDr:0 FmEdp:0
3/8 LP Depth EgAm:0 Kscl:12
4/8 Lowpass CutOff-Modulators Src1: Dph1: Src2: Dph2:
5/8 Lowpass Resonance-Modulators Src1: Dph1: Src2: Dph2:
6/8 LP Feed BusV:100 Pan:<C> FB:0 MM:0
7/8 LP FM Exp from LPFMX:0 LPFMX:0 LPFMX:0 LPFMX:0
8/8 LP FM Lin from LPFML:0 LPFML:0 LPFML:0 LPFML:0
via [CUTOFF MM] or [RESO MM]
1/7 MM LFO FmWve:0 FmRte:0 FmDpt:0
2/7 MM LFO FmEDl:0 FmEDa:0 FmEDr:0 FmEdp:0
3/7 MM Depth EgAm:0 Kscl:12
4/7 Multimode CutOff-Modulators Src1: Dph1: Src2: Dph2:
5/7 Multimode Resonance-Modulators Src1: Dph1: Src2: Dph2:
6/7 MM Feed BusV:100 Pan:<C> FB:0 MM:0
7/7 MM FM MMFMX:0 MMFMX:0 MMFMX:0 MMFMX:0
via [EG DEPTH]
1/6 MM EG Att:0 ^Dcy:12 Stn:104 Rls:23
2/6 LP EG Att:0 ^Dcy:12 Stn:104 Rls:23
3/6 MM Cutoff Att:0 ^Dcy:12 Stn:104 Rls:23
4/6 LP Cutoff Att:0 ^Dcy:12 Stn:104 Rls:23 5/6 LP Ctrl Exp:55 Reso:12 FX1:0 LPBP:0
6/6 LP Ctrl Exp:55 Reso:12 FX1:0 LPBP:0
VCA
via [VCA LEVEL]
Filter to Bus MM:232 LP:100 FB:0
via [FB BALANCE]
Filter Pan Pan:<C> Pan:<C>
via [EG BALANCE]
1/8 VCO1 EG Att:0 ^Dcy:12 Stn:104 Rls:23
2/8 VCO2 EG Att:0 ^Dcy:12 Stn:104 Rls:23
3/8 VCO3 EG Att:0 ^Dcy:12 Stn:104 Rls:23
4/8 VCO4 EG Att:0 ^Dcy:12 Stn:104 Rls:23
5/8 Noise EG Att:0 ^Dcy:12 Stn:104 Rls:23
6/8 MM12 Envelope Att:0 ^Dcy:12 Stn:104 Rls:23
7/8 LP24 Envelope Att:0 ^Dcy:12 Stn:104 Rls:23
8/8 FB Envelope Att:0 ^Dcy:12 Stn:104 Rls:23
Trigger Menu
via [ANALOG SYNTH] press for at least 2 seconds
1/4:S01:<Song01> PA01:<PattA01> Pa12 [Part12] [Part13] [Part14] [current]
2/4: Trigger-Group VCOs VCO1:TG1 VCO2:TG1 VCO3:TG1 VCO4:TG1
3/4: Trigger-Group Filter, Noise MM:TG1 LP:TG1 NSE:TG1 FB:TG1
4/4: Trigger-Group Note-Priority TG1:HIGH TG2:HIGH TG3:HIGH
Digital Synth
VCA
via [OSC WAVE]
OSC WAVE C:Category S:Subactegory SampleName [Init]
via [MACRO CTRL]
1/2: OSC Sample Playback Mode Start:0 StartM:0 Mode:Poly Detn:0
2/2: OSC Sample Playback Mode VDir:NORM
via [OSC DETUNE]
1/2 Voice Modulators Src1: Dph1: Src2: Dph2:
2/2 Voice Modulators Mw:0 Vel:0
LFO
via [LFO WAVE]
LFO Wave Menu Lfo1:12 Lfo2:121
via [MOD DEPTH]
LFO Depth Menu ^Lfo1:127 ^Lfo2:13
1/2 LFO 1 Depth Modifier Menu LEDl:0 LEAT:0 LERl:0 LEDp:0
2/2 LFO 1 Depth Modifier Menu LMWD:0
1/2 LFO 2 Depth Modifier Menu LEDl:0 LEAT:0 LERl:0 LEDp:0
2/2 LFO 2 Depth Modifier Menu LMWD:0
via [MOD RATE]
LFO Rate Menu Lfo1:14 Lfo2:56
VCF
via [CUTOFF LP] or [CUTOFF MM]
1/3:Filter Parameters Scale:12 Ptich:A3
2/3:Filter Cutoff Modulators Src1: Dph1: Src2: Dph2:
3/3:Filter Cutoff Modulators CoMw:0 CoVel:0S
via [RESO LP] or [RESO MM]
1/2:Filter Resonance Modulators Src1: Dph1: Src2: Dph2:
2/2:Filter Resonance Modulators RsMw:0 RsVel:0
via [EG DEPTH]
Cutoff Envelope Att:0 Dcy:24 Stn:55 Rls:33
VCA
via [VCA LEVEL]
1/2:Volume Modulators Src1: Dph1: Src2: Dph2:
2/2:Volume Modulators Mw:0 Vel:0
via [FB BALANCE]
1/2:Pan Modulators Src1: Dph1: Src2: Dph2:
2/2:Pan Modulators Mw:0 Vel:0 Pan:0
via [EG BALANCE]
Volume Envelope Att:0 Dcy:24 Stn:55 Rls:33
Routing Diagram
This is a draft version of a routing diagram of the spectralis signal path.
You may need a special svg viewer for the file like inkscape.
Very special thanks to Lichttank from the spectralis forum for contributing this diagram.
Links
I would like to thank the following people:
- Lichttank from the spectralis forum for contributing the routing diagram.
- Jörg Schaaf for further parameter explanations (and for creating this wonderful machine)
