Yamaha
Yamaha Synthesizer, Japan
Yamaha [1]
the digital era - FM Synthesizers from DX to FS1R
the DX7 got updated for its old style 10bit D/A converters. so the DX7II and DX7IIFD (and dx7s) were born 1987 (read about disk format of it under "digital" or tricks). there was a rack version also: the TX802. the 2nd generation DX7II had unisono mode!! find the DX7II as a rack "TX802" . find unisono in TX816/216,TX802, DX7II series and layer-type sounds on the FS1R,tg/sy models. the DX-21 and DX11/tx81z have performance and/or unison modes ,too! which is very interesting!! sounds fat!
the latest DX7 - based synth is the strongly expanded yamaha FS1R, has 8 OPs and another 8 "unvoiced" OPs with BPF filters and lots more plus formant sequencing. Yamaha DX-7II Centennial: there was a special version in 1988 with 76 keys, 32voices, means 2 DX7IIs in one case.. rare of course like the silver version of the DX7.
there is another very rare 8OP "vintage" synthesizer from 1988 called yamaha FVX1
it's high price may have shocked the ppl and helped not to sell it much, had also FX on board.
but before the FS1R, yamaha had the big SY and TG series:
YAMAHA SY77 and TG77 that had samples on board and the first FM synthesiizers form yamaha with filters (well you do not necessarly need them in an fm synth) 2 filters to be exact. also extra env for pan and samples that could be included in the FM signal path (As an operator), had 3 feddback lines instead of 1, the FS1R also has only 1 feedback line. also the TG77 , SY77 and SY99 all had a free assignable algorithm. the SY99 had some ram slots to use OWN samples with!!.. 4 slots, 512MB each. available. thats the main difference and the 2 spx900 FX processors. the TG77 had ind. outs. the SY77 and TG77 had a smaller fx unit, but also 2x2 FX sections as the SY99 but no sample ram. also the tg and sy synths could route the pitch env individually to the OPs unlike all other yamaha fm synthesizers.
the latest one is the DX7 as a "plugin hardware" that can be attached to some newer yamaha keyboards and the dx200 groovebox, that has a DX7 and a 16step sequencer in it.. (german: deutscher test hier zu lesen!)
typical: DX1, DX5, DX7, GS1/2 (ok, these are generation 0) 1st generation DX series (80ies, a bit rough sounding 10bit converters): DX1,DX5, TX7, DX9, TX816 / TX216, DX21
at the same time yamaha put out the 4 OP systems (cheaper), DX9 (1983) and later the DX21 that had split and dual mode like the DX5 and the poly mode only synths DX27, DX100 etc.. all 4OP synthesizers. tx81z more 4 OP synthesizers? the V50 workstation, DX11 (the first 4OP - multimode dx!), TX-81z (racked DX11),FB01 small module in a "cheap" looking case. (smaller than 19", not rackable but an expander)..
also they introduced rack modules like the TX-7 (the non-rackable but desktop DX-7) and the big TX816 . it had lots of tf1 modules that represent ONE DX7 each,so you could eqasily have 8 DX-7's in a rack!.. the TX216 had 2 TF1 modules 1985.
the dx or fm synthesis is well known for bell and rhodes sounds, but it can do much more than that!! or fm basses got popular in the 90ies ;) but autechre and other new electro bands showed there is another use of fm synthesis sounds!!
second generation FM Synthesizers
very cheap 4OP synth with 8xmultitimbral synth. you can change everything as long as you use a software editor. but: well, for FM you should consider editor software anyway. the 4OP and 6OP Range also took place in Yamahas "keyboard" range and some "exotic" keyboards (cheap to mid price range). even sound cards..
3rd generation FM Synthesizers
TG77,SY77, SY99 added samples (77:rom, 99: ram), designing your own algorithms and up to 3 feedbacks and nice spx like FX (spx1000 x2 on the SY99) and : from now on no1 could say FM sounds thin!! thats still refering to the 1st/2nd gen fm synths .. 20bit AD now.. more hi-end sound but some prefer the 2nd generation for "authentic" dx sound (rough and hard) we are talking about small changes..
4th generation FM Synthesizers
FS1R , the only 8 OP + 8 OP(unvoiced) synth!
5th generation FM Synthesizers
dx200, plugin concept: works on most yamaha workstation called plg100dx (beside modules for physical modeling aka vl70m, piano and VA (called AN) etc.. well ,the dx-200 is almost soundwise the "2nd generation"..
