Radikal Spectralis
Aus Synthesizer Wiki
Radikal Technologies Spectralis Groovebox / Sequencer
features
  • Hybrid Synth with 4 OSCs & Moog style analog 24 dB LP Filter and 12 dB analog Multimode Filter (4 Filter Types)
  • 192th resolution chase light sequencer that can handle independent Tracks (back & forth) and Trigger little "Track Envelopes" as a Modulation Source.
  • Filterbank
  • Samples 96MB
features - deutsch
  • 192tel Auflösung des Lauflicht-Sequencers
  • Hybrid Synthesizer mit Moog Filter Kaskade
  • Filterbank
  • Samples 96MB
Tips & Tricks
  • quick switch between 2 different OSC pages
you can switch directly between two OSC pages using the [OSC WAVE] & MACRO CTRL encoder
[OSC WAVE] memorizes the last selected page
[MACRO CTRL] memorizes any page between 10 and 26
Sometimes an Encoder memorizes two pages - needs further investigation and description
Display Reference
Analog Synth
VCO
via [OSC WAVE] or [MACRO CTRL]
 Page 1/26 VCO Shape
 ^Osc1-4  - Oscillator Waveform 0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle
  1/2:VCO? WAVE
  ^Shape:255 ^Tlm:100 Sync:0 Ring:off (Sync OSC1 only | Ring OSC4 only)  Tlm = Time Linearity Modulation kind of Pulse Width Modulation
   VCO ? Waveform Modulation
   Src1:  Dpth1:  Src2: Dpth2:
   VCO ? Tlm Modulation
  2/2:VCO? WAVE
  O3PM:0 O4PM:0 O3FM:0 O4FM:0  Osc3 & 4 can be used for either PhaseModulation (like yamaha FM) or real FM
 2/26:VCO EG
 ^Osc1-4:0 Oscillator Envelope macro - adjust ADSR Envelope with just one dial
Subpages see Envelopes Section which contains all AnalogSynth Envelopes
 3/26:VCO FB Volume
 Osc1-4 Filterbank Feed Level
 4/26:VCO MM Volume
 Osc1-4 12dB Multimode Filter Feed Level
 5/26:VCO LP Volume
 Osc1-4 24dB LP Filter Feed Level
 6/26:VCO FX1 Send
 Osc1-4 FX1 Send
 7/26:VCO Bus Volume
 Osc1-4 Bus Volume Level
 8/26:VCO Bus Panning
 Osc1-4 Bus Panning
 9/26:VCO EG Bypass
 Osc1-4 EG Bybass Level - set to max to deactivate VCO EG
 10/26:VCO1 TLM
 TlmM:0 TlmF:VCO? WaveM:0 WaveF:VCO?
11-13 contain the same settings for VCO2-4
 14/26:VCO1 Div1
 Sync:0 Glide:0 Pitch:A3 Scale:12
 15/26:VCO2 Div1
 16/26:VCO3 Div1
 17/26:VCO1 Div1
 Ring:OFF Glide:0 Pitch:A3 Scale:12
 18/26:VCO1 Div2
 Crush:0 Phs:0 FmDp:0 PMod:2
19-21 contain the same settings for VCO2-4
 22/26 Noise EG Feed
 FB:0 LP:0 MM:0 Bus:0
 23/26 Noise Direct Feed
 24/26 VCO Key->Level
 ^Osc?:0
  1/4:VCO1 KSL
  Pitch:C-3 Pitch:C-3 Pitch:C-3 KsSc:12     - explanation needed
2-4 contain the same settings for VCO2-4
 25/26 VCO Vel->Level
 Osc?:0
 26/26 VCO Phase
 Osc?:0  - collection of all Osc Phase settings that can also be found on the VCO Div2 pages
via [OSC DETUNE]
 1/4 VCO Fine
 ^Osc?:0
  1/12 VCO Fine Tune Modulation
  KeyPt:0 RndPt:0 VibSp:0
  2/12 VCO Pitch LFO
  LWve:0 LRte:0 LDpt:0
  3/12 VCO Pitch Modulation
  Src1: Dph1: Src2: Dph2:
4-12 contain the same settings for VCO2-4
 2/4 VCO Coarse
 ^Osc?:0
  VCO Pitch Envelope Preset
  ^Osc?:0
   1/4:VCO1 Pitch
   StPt:0 Time:0 Time:0 EndP:0
 3/4 VCO Key Scale
 Osc?:0 - collection of all VCO Key Scale settings that can also be found on the VCO Div1 pages
 4/4 VCO0 Pitch Mod
 PMod:0 PMod:0 PMod:0 PMod:0 - collection of all VCO PMod settings that can also be found on the VCO Div2 pages
via [GLIDE]
 VCO Glide
 Glide:0 Glide:0 Glide:0 Glide:0
TODO - OSC Section Picture, Knob & Button modes
LFO
via [LFO WAVE]
 Master LFO Wave Menu
 ^LWve:0 ^LWve:0 ^LWve:0 ^LWve:0  - LFO Waveform 0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle, 255=S&H
  1/4 Master LFO 1 Waveform Control
  LWve:0 LPhs:0
2-4 contain the same settings for LFO2-4
via [MOD DEPTH]
 Master LFO Modulation Depth
 ^LDpt:0 ^LDpt:0 ^LDpt:0 ^LDpt:0
  1/4 Master LFO 1 Depth Control
  LDpth:0 ^LEDp:0
   1/4 LFO 1 Depth Control Envelope
   LEDl:0 LEAT:0 LERl:0 LEDp:0
via [MOD DEPTH]
 Master LFO Rate Menu
 LRte:0 LRte:0 LRte:0 LRte:0
VCF
via [CUTOFF LP] or [RESO LP]
 1/8 LP LFO
 FmWve:0 FmRte:0 FmDpt:0
 2/8 LP LFO
 FmEDl:0 FmEDa:0 FmEDr:0  FmEdp:0
 3/8 LP Depth
 EgAm:0 Kscl:12
 4/8 Lowpass CutOff-Modulators
 5/8 Lowpass Resonance-Modulators
 6/8 LP Feed
 BusV:100 Pan:<C> FB:0 MM:0
 7/8 LP FM Exp from
 LPFMX:0 LPFMX:0 LPFMX:0 LPFMX:0
 8/8 LP FM Lin from
 LPFML:0 LPFML:0 LPFML:0 LPFML:0
via [CUTOFF MM] or [RESO MM]
 1/7 MM LFO
 2/7 MM LFO
 3/7 MM Depth
 EgAm:0 Kscl:12
 4/7 Multimode CutOff-Modulators
 5/7 Multimode Resonance-Modulators
 6/7 MM Feed
 7/7 MM FM
 MMFMX:0 MMFMX:0 MMFMX:0 MMFMX:0
via [EG DEPTH]
 1/6 MM EG
 Att:0 ^Dcy:12 Stn:104 Rls:23
 2/6 LP EG
 3/6 MM Cutoff
 4/6 LP Cutoff
 5/6 LP Ctrl
 Exp:55 Reso:12 FX1:0 LPBP:0
 6/6 LP Ctrl
VCA
via [VCA LEVEL]
 Filter to Bus
 MM:232 LP:100 FB:0
via [FB BALANCE]
 Filter Pan
 Pan:<C> Pan:<C>
via [EG BALANCE]
 1/8 VCO1 EG
 2/8 VCO2 EG
 3/8 VCO3 EG
 4/8 VCO4 EG
 5/8 Noise EG
 6/8 MM12 Envelope
 7/8 LP24 Envelope
 8/8 FB Envelope
Trigger Menu
via [ANALOG SYNTH] press for at least 2 seconds
 1/4:S01:<Song01> PA01:<PattA01> Pa12
 [Part12] [Part13]  [Part14] [current]
 2/4: Trigger-Group VCOs
 VCO1:TG1 VCO2:TG1 VCO3:TG1 VCO4:TG1
 3/4: Trigger-Group Filter, Noise
 MM:TG1 LP:TG1 NSE:TG1 FB:TG1
 4/4: Trigger-Group Note-Priority
 TG1:HIGH TG2:HIGH TG3:HIGH
Digital Synth
VCA
via [OSC WAVE]
 OSC WAVE
 C:Category S:Subactegory SampleName  [Init]
via [MACRO CTRL]
 1/2: OSC Sample Playback Mode
 Start:0 StartM:0 Mode:Poly Detn:0
 2/2: OSC Sample Playback Mode
 VDir:NORM
via [OSC DETUNE]
 1/2 Voice Modulators
 2/2 Voice Modulators
 Mw:0 Vel:0
LFO
via [LFO WAVE]
 LFO Wave Menu
 Lfo1:12 Lfo2:121
via [MOD DEPTH]
 LFO Depth Menu
 ^Lfo1:127 ^Lfo2:13
   1/2 LFO 1 Depth Modifier Menu
   2/2 LFO 1 Depth Modifier Menu
   LMWD:0
   1/2 LFO 2 Depth Modifier Menu
   2/2 LFO 2 Depth Modifier Menu
   LMWD:0
via [MOD RATE]
 LFO Rate Menu
 Lfo1:14 Lfo2:56
VCF
via [CUTOFF LP] or [CUTOFF MM]
 1/3:Filter Parameters
 Scale:12 Ptich:A3
 2/3:Filter Cutoff Modulators
 3/3:Filter Cutoff Modulators
 CoMw:0 CoVel:0S
via [RESO LP] or [RESO MM]
 1/2:Filter Resonance Modulators
 2/2:Filter Resonance Modulators
 RsMw:0 RsVel:0
via [EG DEPTH]
 Cutoff Envelope
 Att:0 Dcy:24 Stn:55 Rls:33
VCA
via [VCA LEVEL]
 1/2:Volume Modulators
 2/2:Volume Modulators
 Mw:0 Vel:0
via [FB BALANCE]
 1/2:Pan Modulators
 2/2:Pan Modulators
 Mw:0 Vel:0  Pan:0
via [EG BALANCE]
 Volume Envelope
http://www.sequencer.de/syns/radikal/Spectralis.html
