Radikal Spectralis
Aus Synthesizer Wiki
Radikal Technologies Spectralis Groovebox / Sequencer
important features
  • Hybird Synth with 4 OSCs & Moog style analog 24 dB LP Filter and 12 dB analog Multimode Filter
  • 192th resolution chase light sequencer
  • Filterbank
  • Samples 96MB
deutsch
  • 192tel Auflösung des Lauflicht-Sequencers
  • Hybrid Synthesizer mit Moog Filter Kaskade
  • Filterbank
  • Samples 96MB
Tips & Tricks
  • quick switch between 2 different OSC pages
you can switch directly between two OSC pages using the [OSC WAVE] & MACRO CTRL encoder
[OSC WAVE] memorizes the last selected page
[MACRO CTRL] memorizes any page between 10 and 26
Display Reference
Analog Synth
VCO via [OSC WAVE] or [MACRO CTRL]
Page 1/26 VCO Shape
^Osc1-4  - Oscillator Waveform 0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle
 1/2:VCO? WAVE
 ^Shape:255 ^Tlm:100 Sync:0 Ring:off (Sync OSC1 only | Ring OSC4 only)  Tlm = Time Linearity Modulation kind of Pulse Width Modulation
  VCO ? Waveform Modulation
  Src1:  Dpth1:  Src2: Dpth2:
  VCO ? Tlm Modulation
 2/2:VCO? WAVE
 O3PM:0 O4PM:0 O3FM:0 O4FM:0  Osc3 & 4 can be used for either PhaseModulation (like yamaha FM) or real FM
2/26:VCO EG
^Osc1-4:0 Oscillator Envelope macro - adjust ADSR Envelope with just one dial
Subpages see Envelopes Section which contains all AnalogSynth Envelopes
3/26:VCO FB Volume
Osc1-4 Filterbank Feed Level
4/26:VCO MM Volume
Osc1-4 12dB Multimode Filter Feed Level
5/26:VCO LP Volume
Osc1-4 24dB LP Filter Feed Level
6/26:VCO FX1 Send
Osc1-4 FX1 Send
7/26:VCO Bus Volume
Osc1-4 Bus Volume Level
8/26:VCO Bus Panning
Osc1-4 Bus Panning
9/26:VCO EG Bypass
Osc1-4 EG Bybass Level - set to max to deactivate VCO EG
 10/26:VCO1 TLM
 TlmM:0 TlmF:VCO? WaveM:0 WaveF:VCO?
11-13 contain the same settings for VCO2-4
 14/26:VCO1 Div1
 Sync:0 Glide:0 Pitch:A3 Scale:12
 15/26:VCO2 Div1
 16/26:VCO3 Div1
 17/26:VCO1 Div1
 Ring:OFF Glide:0 Pitch:A3 Scale:12
 18/26:VCO1 Div2
 Crush:0 Phs:0 FmDp:0 PMod:2
19-21 contain the same settings for VCO2-4
 22/26 Noise EG Feed
 FB:0 LP:0 MM:0 Bus:0
 23/26 Noise Direct Feed
 24/26 VCO Key->Level
 ^Osc?:0
  1/4:VCO1 KSL
  Pitch:C-3 Pitch:C-3 Pitch:C-3 KsSc:12     - explanation needed
2-4 contain the same settings for VCO2-4
 25/26 VCO Vel->Level
 Osc?:0
 26/26 VCO Phase
 Osc?:0  - collection of all Osc Phase settings that can also be found on the VCO Div2 pages
via [OSC DETUNE]
 1/4 VCO Fine
 ^Osc?:0
  1/12 VCO Fine Tune Modulation
  KeyPt:0 RndPt:0 VibSp:0
  2/12 VCO Pitch LFO
  LWve:0 LRte:0 LDpt:0
  3/12 VCO Pitch Modulation
  Src1: Dph1: Src2: Dph2:
4-12 contain the same settings for VCO2-4
 2/4 VCO Coarse
 ^Osc?:0
  VCO Pitch Envelope Preset
  ^Osc?:0
   1/4:VCO1 Pitch
   StPt:0 Time:0 Time:0 EndP:0
 3/4 VCO Key Scale
 Osc?:0 - collection of all VCO Key Scale settings that can also be found on the VCO Div1 pages
 4/4 VCO0 Pitch Mod
 PMod:0 PMod:0 PMod:0 PMod:0 - collection of all VCO PMod settings that can also be found on the VCO Div2 pages
via [GLIDE]
 VCO Glide
 Glide:0 Glide:0 Glide:0 Glide:0
TODO - OSC Section Picture, Knob & Button modes
LFO via [LFO WAVE]
 Master LFO Wave Menu
 ^LWve:0 ^LWve:0 ^LWve:0 ^LWve:0  - LFO Waveform 0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle, 255=S&H
  1/4 Master LFO 1 Waveform Control
  LWve:0 LPhs:0
2-4 contain the same settings for LFO2-4
via [MOD DEPTH]
 Master LFO Modulation Depth
 ^LDpt:0 ^LDpt:0 ^LDpt:0 ^LDpt:0
  1/4 Master LFO 1 Depth Control
  LDpth:0 ^LEDp:0
   1/4 LFO 1 Depth Control Envelope
   LEDl:0 LEAT:0 LERl:0 LEDp:0
via [MOD DEPTH]
 Master LFO Rate Menu
 LRte:0 LRte:0 LRte:0 LRte:0
http://www.sequencer.de/syns/radikal/Spectralis.html
