Radikal Spectralis
Radikal Technologies Spectralis Groovebox / Sequencer
important features
- Hybird Synth with 4 OSCs & Moog style analog 24 dB LP Filter and 12 dB analog Multimode Filter
- 192th resolution chase light sequencer
- Filterbank
- Samples 96MB
deutsch
- 192tel Auflösung des Lauflicht-Sequencers
- Hybrid Synthesizer mit Moog Filter Kaskade
- Filterbank
- Samples 96MB
Tips & Tricks
- quick switch between 2 different OSC pages
you can switch directly between two OSC pages using the [OSC WAVE] & MACRO CTRL encoder
[OSC WAVE] memorizes the last selected page
[MACRO CTRL] memorizes any page between 10 and 26
Display Reference
Analog Synth
VCO via [OSC WAVE] or [MACRO CTRL]
Page 1/26 VCO Shape ^Osc1-4 - Oscillator Waveform 0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle
1/2:VCO? WAVE ^Shape:255 ^Tlm:100 Sync:0 Ring:off (Sync OSC1 only | Ring OSC4 only) Tlm = Time Linearity Modulation kind of Pulse Width Modulation
VCO ? Waveform Modulation Src1: Dpth1: Src2: Dpth2:
VCO ? Tlm Modulation Src1: Dpth1: Src2: Dpth2:
2/2:VCO? WAVE O3PM:0 O4PM:0 O3FM:0 O4FM:0 Osc3 & 4 can be used for either PhaseModulation (like yamaha FM) or real FM
2/26:VCO EG ^Osc1-4:0 Oscillator Envelope macro - adjust ADSR Envelope with just one dial
Subpages see Envelopes Section which contains all AnalogSynth Envelopes
3/26:VCO FB Volume Osc1-4 Filterbank Feed Level
4/26:VCO MM Volume Osc1-4 12dB Multimode Filter Feed Level
5/26:VCO LP Volume Osc1-4 24dB LP Filter Feed Level
6/26:VCO FX1 Send Osc1-4 FX1 Send
7/26:VCO Bus Volume Osc1-4 Bus Volume Level
8/26:VCO Bus Panning Osc1-4 Bus Panning
9/26:VCO EG Bypass Osc1-4 EG Bybass Level - set to max to deactivate VCO EG
10/26:VCO1 TLM TlmM:0 TlmF:VCO? WaveM:0 WaveF:VCO?
11-13 contain the same settings for VCO2-4
14/26:VCO1 Div1 Sync:0 Glide:0 Pitch:A3 Scale:12
15/26:VCO2 Div1 Glide:0 Pitch:A3 Scale:12
16/26:VCO3 Div1 Glide:0 Pitch:A3 Scale:12
17/26:VCO1 Div1 Ring:OFF Glide:0 Pitch:A3 Scale:12
18/26:VCO1 Div2 Crush:0 Phs:0 FmDp:0 PMod:2
19-21 contain the same settings for VCO2-4
22/26 Noise EG Feed FB:0 LP:0 MM:0 Bus:0
23/26 Noise Direct Feed FB:0 LP:0 MM:0 Bus:0
24/26 VCO Key->Level ^Osc?:0
1/4:VCO1 KSL Pitch:C-3 Pitch:C-3 Pitch:C-3 KsSc:12 - explanation needed
2-4 contain the same settings for VCO2-4
25/26 VCO Vel->Level Osc?:0
26/26 VCO Phase Osc?:0 - collection of all Osc Phase settings that can also be found on the VCO Div2 pages
via [OSC DETUNE]
1/4 VCO Fine ^Osc?:0
1/12 VCO Fine Tune Modulation KeyPt:0 RndPt:0 VibSp:0
2/12 VCO Pitch LFO LWve:0 LRte:0 LDpt:0
3/12 VCO Pitch Modulation Src1: Dph1: Src2: Dph2:
4-12 contain the same settings for VCO2-4
2/4 VCO Coarse ^Osc?:0
VCO Pitch Envelope Preset ^Osc?:0
1/4:VCO1 Pitch StPt:0 Time:0 Time:0 EndP:0
3/4 VCO Key Scale Osc?:0 - collection of all VCO Key Scale settings that can also be found on the VCO Div1 pages
4/4 VCO0 Pitch Mod PMod:0 PMod:0 PMod:0 PMod:0 - collection of all VCO PMod settings that can also be found on the VCO Div2 pages
via [GLIDE]
VCO Glide Glide:0 Glide:0 Glide:0 Glide:0
TODO - OSC Section Picture, Knob & Button modes
LFO via [LFO WAVE]
Master LFO Wave Menu ^LWve:0 ^LWve:0 ^LWve:0 ^LWve:0 - LFO Waveform 0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle, 255=S&H
1/4 Master LFO 1 Waveform Control LWve:0 LPhs:0
2-4 contain the same settings for LFO2-4
via [MOD DEPTH]
Master LFO Modulation Depth ^LDpt:0 ^LDpt:0 ^LDpt:0 ^LDpt:0
1/4 Master LFO 1 Depth Control LDpth:0 ^LEDp:0
1/4 LFO 1 Depth Control Envelope LEDl:0 LEAT:0 LERl:0 LEDp:0
Master LFO Rate Menu LRte:0 LRte:0 LRte:0 LRte:0
