Radikal Spectralis
Aus Synthesizer Wiki
Radikal Technologies Spectralis Groovebox / Sequencer
important features
  • Hybird Synth with 4 OSCs & Moog style analog 24 dB LP Filter and 12 dB analog Multimode Filter
  • 192th resolution chase light sequencer
  • Filterbank
  • Samples 96MB
deutsch
  • 192tel Auflösung des Lauflicht-Sequencers
  • Hybrid Synthesizer mit Moog Filter Kaskade
  • Filterbank
  • Samples 96MB
Tips & Tricks
  • quick switch between 2 different OSC pages
you can switch directly between two OSC pages using the [OSC WAVE] & MACRO CTRL encoder
[OSC WAVE] memorizes the last selected page
[MACRO CTRL] memorizes any page between 10 and 26
Display Reference
Analog Synth
VCO via [OSC WAVE] or [MACRO CTRL]
Page 1/26 VCO Shape
^Osc1-4  - Oscillator Waveform 0=Sine, 64=Triangle, 127=Sawtooth, 196=Rectangle
 1/2:VCO? WAVE
 ^Shape:255 ^Tlm:100 Sync:0 Ring:off (Sync OSC1 only | Ring OSC4 only)  Tlm = Time Linearity Modulation kind of Pulse Width Modulation
  VCO ? Waveform Modulation
  Src1:  Dpth1:  Src2: Dpth2:
  VCO ? Tlm Modulation
 2/2:VCO? WAVE
 O3PM:0 O4PM:0 O3FM:0 O4FM:0  Osc3 & 4 can be used for either PhaseModulation (like yamaha FM) or real FM
2/26:VCO EG
^Osc1-4:0 Oscillator Envelope macro - adjust ADSR Envelope with just one dial
Subpages see Envelopes Section which contains all AnalogSynth Envelopes
3/26:VCO FB Volume
Osc1-4 Filterbank Feed Level
4/26:VCO MM Volume
Osc1-4 12dB Multimode Filter Feed Level
5/26:VCO LP Volume
Osc1-4 24dB LP Filter Feed Level
6/26:VCO FX1 Send
Osc1-4 FX1 Send
7/26:VCO Bus Volume
Osc1-4 Bus Volume Level
8/26:VCO Bus Panning
Osc1-4 Bus Panning
9/26:VCO EG Bypass
Osc1-4 EG Bybass Level - set to max to deactivate VCO EG
 10/26:VCO1 TLM
 TlmM:0 TlmF:VCO? WaveM:0 WaveF:VCO?
11-13 contain the same settings for VCO2-4
 14/26:VCO1 Div1
 Sync:0 Glide:0 Pitch:A3 Scale:12
 15/26:VCO2 Div1
 16/26:VCO3 Div1
 17/26:VCO1 Div1
 Ring:OFF Glide:0 Pitch:A3 Scale:12
 18/26:VCO1 Div2
 Crush:0 Phs:0 FmDp:0 PMod:2
19-21 contain the same settings for VCO2-4
 22/26 Noise EG Feed
 FB:0 LP:0 MM:0 Bus:0
 23/26 Noise Direct Feed
 24/26 VCO Key->Level
 ^Osc?:0
  1/4:VCO1 KSL
  Pitch:C-3 Pitch:C-3 Pitch:C-3 KsSc:12     - explanation needed
2-4 contain the same settings for VCO2-4
 25/26 VCO Vel->Level
 Osc?:0
 26/26 VCO Phase
 Osc?:0  - collection of all Osc Phase settings that can also be found on the VCO Div2 pages
http://www.sequencer.de/syns/radikal/Spectralis.html
