Chips in Synthesizers
Hardware Chips - Synthesizer
- SSM or
- CEM Chips (List of CEM Models / Alle CEMs hier)
- Discrete Analogue
- digital: DSP -> (Motorola or Sharc) or some custom.
List Synthesizers - Analog + Vintage
AX80 6 CEM3372 uP Signal Processor -CEM3372 Filter/Mix/VCA
Banana (created by Synthesizerstudio Bonn, since 1999 the SSB is closed..)
DSI /SCI see SCI/Sequential
A107 Morph. Filter: CEM3379 A121 Multi Mode Filter: CEM3320 A122 LPFilter: CEM3320 A123 HPFilter: CEM3320
A-109 VC Signal Processor (CEM3379) A-111-1 High End VCO (CEM3340) A-130 VCA (linear)/A-131 VCA (exp.) (früher/earlier: CEM3381/CEM3382, heute/today CA3080) A-134 VC Panning (CEM3381)
Und vermutlich - possibly: A111-2 Dyn. VCO CEM3394.
Synthex 8 CEM3320 VCF
Mirage 8 CEM3328 VCF
Kawai K3
____________________________________________________________
DSS1 / DSM1 SSM (no?)
Poly 61 6 SSM2056 EG
more v'ger see my moog page..
Prommer 1 CEM3328 VCF
Wave 2.2 / 2.3 4 CEM3320 VCF 4 CEM3310 EG
Wave 2.0 8 SM2044 VCF - info: - ssm2044.pdf 4 CEM3360 Dual VCA The PPG Wave (2.0) series used the SSM filter.
Fender / Rhodes
Roland SH101 and MC202 1 CEM3340 VCO roland sh101 MKS-20 5 CEM3360 Dual VCA
VS
1 CEM5510 Fast Sample/Hold
1 CEM5530 30ch S/H
8 CEM3382 Dual Low Noise VCA
8 CEM3378 VC Signal Processor - CEM3372 Filter/Mix/VCA
UPDATE: VS used 2 x CEM5530,4 X CEM 5510 (8chan s/h),2 X CEM3365(dual vca for vector mix)
PROPHET 5 - the first Prophet 5 series used the SSM filter, laterthey were changed to CEM
Prophet 5 Rev 3
11 CEM3340 VCO
10 CEM3310 EG
5 CEM3320 VCF
MAX 6 CEM3394 uP Voice
Simmons Drums
SDS8
5 CEM3372 VC Signal Generator -->CEM3372 Filter/Mix/VCA
Microwave microwave 1 8 CEM3387 VCF,VCA,VCP (later models) 8 CEM3389 VCF,VCA,VCP (early models) the revision was app. at the same time as waldorf changed to the Nextel-Housing --> "old" eloxiertes Gehäuse (housing) = 3389 - Nextel-Gehäuse (housing) = 3387 it's know exactly know if there are also a small amount of old/new CEMs in the vice versa housings, but it is most likely the same date.. ;) microwave 1 opened
the Q naked (non analogue version) BOARD - eine nackte nichtanaloge Kuh PLATINE ;-) (thanks to midicase.com! for the pic of the board!)
waldorf q boardwaldorf q+
DSPs
what DSP in what synthesizer? - welcher DSP in welchem synthesizer?
waldorf q board
Access Virus A --- Motorola 56303 Access Virus B --- Motorola 56311 virus c - unknown motorola (1x DSP !) virus caccess virus C
Quasimidi Polymorph --- Dream SAM9707
EMU Coldfire 33Mhz for the Audity2000 and 40Mhz for the Proteus2000
btw: please keep in mind that the only cool 303 is the 56303 ;-)
Links
