Modulus Monowave
Modulus Monowave
monophonic simple Synthesizer with 2 digital oscillators with the waveshapes of many well known Wavetable synth. These waveshapes are not wavetables. But the same waveshapes found for exsample in the PPG waves. The filter is a Moog clone. The 2 ADSRs are fully analog.
Not based on the Waldorf Microwave (very different technics, but sharing all the classic PPG waveshapes).
Best mix of the digital waveshapes and a strong filter, but it's a bit limited like
LFO only around 10 Hz (later added software oLFO because of user requests)
On the other hand the Arpeggiator is way more tight to midi clocks and speed changed then all others by pro companies. And it starts the arpeggio allways with a quantise function (depending on the used clock ratio) on the right midi clock beat. This is unique.
Made by Paul Maddox
