Chips in Synthesizers
Aus Synthesizer Wiki
Hardware Chips - Synthesizer
most are
in here, the Rest is
List Synthesizers - Analog
Akai
AX80 6 CEM3372 uP Signal Processor -CEM3372 Filter/Mix/VCA
Banana (created by Synthesizerstudio Bonn, since 1999 the SSB is closed..)
Cheetah
CMI
Crumar
DSI /SCI see SCI/Sequential
Elka
Synthex 8 CEM3320 VCF
Ensoniq
Mirage 8 CEM3328 VCF
Keytek
Kawai K3
____________________________________________________________ Korg
Poly 61 6 SSM2056 EG
Linn
Moog
more v'ger see my moog page..
Oberheim
Prommer 1 CEM3328 VCF
Paia
PPG
Wave 2.2 / 2.3 4 CEM3320 VCF 4 CEM3310 EG
Wave 2.0 8 SM2044 VCF - info: - ssm2044.pdf 4 CEM3360 Dual VCA The PPG Wave (2.0) series used the SSM filter.
Fender / Rhodes
Roland
Roland SH101 and MC202 1 CEM3340 VCO roland sh101 MKS-20 5 CEM3360 Dual VCA
RSF
Sequential Circuits / DSI
VS 1 CEM5510 Fast Sample/Hold 1 CEM5530 30ch S/H 8 CEM3382 Dual Low Noise VCA 8 CEM3378 VC Signal Processor - CEM3372 Filter/Mix/VCA UPDATE: VS used 2 x CEM5530,4 X CEM 5510 (8chan s/h),2 X CEM3365(dual vca for vector mix)
PROPHET 5 - the first Prophet 5 series used the SSM filter, laterthey were changed to CEM Prophet 5 Rev 3 11 CEM3340 VCO 10 CEM3310 EG 5 CEM3320 VCF
MAX 6 CEM3394 uP Voice
Siel
Simmons Drums
SDS8 5 CEM3372 VC Signal Generator -->CEM3372 Filter/Mix/VCA
Solton
Steiner Parker
Synton
Waldorf
Microwave microwave 1 8 CEM3387 VCF,VCA,VCP (later models) 8 CEM3389 VCF,VCA,VCP (early models) the revision was app. at the same time as waldorf changed to the Nextel-Housing --> "old" eloxiertes Gehäuse (housing) = 3389 - Nextel-Gehäuse (housing) = 3387 it's know exactly know if there are also a small amount of old/new CEMs in the vice versa housings, but it is most likely the same date.. ;) microwave 1 opened
the Q naked (non analogue version) BOARD - eine nackte nichtanaloge Kuh PLATINE ;-) (thanks to midicase.com! for the pic of the board!)
waldorf q boardwaldorf q+
Yamaha
DSPs
what DSP in what synthesizer? - welcher DSP in welchem synthesizer?
Waldorf
waldorf q board
Korg
Clavia
Novation
Radikal
Creamware
Access
Access Virus A --- Motorola 56303 Access Virus B --- Motorola 56311 virus c - unknown motorola (1x DSP !) virus caccess virus C
Quasimidi
Quasimidi Polymorph --- Dream SAM9707
Alesis
Emu
EMU Coldfire 33Mhz for the Audity2000 and 40Mhz for the Proteus2000
btw: please keep in mind that the only cool 303 is the 56303 ;-)
Links
