Curtis CEM Chips
Curtis Analogue Synthesis Chips
CEM = Curtis Electromusic Specialities - s special analogue small scale chip. by Doug Curtis (died 1/2007)
where to get CEMs
- USA : synthtech.com (motm..)
- Paul Schreiber is the current stock-piler of all things CEM/SSM, and he has a list on his site about what's where: http://www.synthtech.com/cem/cemdata.html
- Germany : Micon Chip Distribution, http://www.heinz-bacher-gmbh.de
- Dave Smith has a special amount of CEMs for the Evolver series (new ones) but its unique and a special deal... so he will not sell them
Curtis Chips List
- CEM3310 ENV ADSR
- CEM3312 ADSR + VCA
- CEM3318 ADSR but microprocessor controlled
- CEM3320 24dB/Oct. Filter (multi)
- CEM3328 same but LPF only
- CEM3330 exp/lin VCA
- CEM3335 exp VCA
- CEM3340 VCO (Saw,Tri,Pulse)
- CEM3345 VCO (Saw,Tri,Pulse) with comparator
- CEM3350 12dB/oct Multimode Filter x2 (no notch)
- CEM3360 VCA x2
- CEM3365 DAC
- CEM3371 Envelope x2
- CEM3372 24dB/oct. Filter, Mix, VCA
- CEM3374 VCO x2 (PWMable Pulse, Tri, Saw)
- CEM3378 24dB/oct. Filter, Mix, VCA but microprocessor controlled
- CEM3379 24dB/oct. Filter, Mix, VCA but microprocessor controlled
- CEM3381 VCA x2 linear
- CEM3382 VCA x2 log.
- CEM3385 24dB/oct Filter (LoFi)
- CEM3387 signal processor 3-4 pole cascade Filter, VC Pan/VCA
- CEM3389 signal processor 4 pole Filter, VC resonance, VC Pan/VCA
- CEM3391 Microprocessor Ctrld: VCF,VCA,Env (ADSR)
- CEM3394 Microprocessor Ctrld: 1 Synth Voice: VCF,VCA,Env (ADSR),VCMix
- CEM3396 Microprocessor Ctrld: Wave-Shaper x2 - VCF,VCA
- PA381 VCA (low noise)
- PA382 VCA (low noise)
- PD508 S/H (8x)
- 5508 predecessor of PD508 same function
- 5530 30ch multiplex sample&hold (Prophet VS)
In what Synths?
List of CEM in Synths [1]
