Chips in Synthesizers
Aus Synthesizer Wiki
Version vom 11. Januar 2007, 23:53 Uhr von Moogulator (Diskussion | Beiträge)
(Unterschied) ← Nächstältere Version | Aktuelle Version (Unterschied) | Nächstjüngere Version → (Unterschied)
Akai
AX-80 6 CEM3372 uP Signal Processor -CEM3372 Filter/Mix/VCA
AX-60 6 CEM3394 uP Voice Akai AX-60 uses 2xMN3101 and 2xMN3009 for it's chorus.
Banana (created by Synthesizer Studio Bonn, since 1999 the SSB is closed..)
Cheetah
CMI
Crumar
DSI /SCI see SCI/Sequential
Elka
Synthex 8 CEM3320 VCF
Ensoniq
Mirage 8 CEM3328 VCF
KeyTek
Kawai K3
____________________________________________________________ Korg
Poly 61 6 SSM2056 EG
Linn
MOOG
more v'ger see my moog page..
Oberheim
Prommer 1 CEM3328 VCF
PAiA
PPG
Wave 2.2 / 2.3 4 CEM3320 VCF 4 CEM3310 EG
Wave 2.0 8 SM2044 VCF - info: - ssm2044.pdf 4 CEM3360 Dual VCA The PPG Wave (2.0) series used the SSM filter.
Fender / Rhodes
Roland
Roland SH101 and MC202 1 CEM3340 VCO roland sh101 MKS-20 5 CEM3360 Dual VCA
RSF
Sequential Circuits / DSI link: DSI..
VS 1 CEM5510 Fast Sample/Hold 1 CEM5530 30ch S/H 8 CEM3382 Dual Low Noise VCA 8 CEM3378 VC Signal Processor - CEM3372 Filter/Mix/VCA UPDATE: VS used 2 x CEM5530,4 X CEM 5510 (8chan s/h),2 X CEM3365(dual vca for vector mix)
PROPHET 5 - the first Prophet 5 series used the SSM filter, laterthey were changed to CEM Prophet 5 Rev 3 11 CEM3340 VCO 10 CEM3310 EG 5 CEM3320 VCF
MAX 6 CEM3394 uP Voice
Siel
Simmons Drums
SDS8 5 CEM3372 VC Signal Generator -->CEM3372 Filter/Mix/VCA
Solton
Steiner
Synton
Waldorf
Wave waldorf wave Inside a 16 voice WAVE: 16 x AD 7545 D/A converter 16 x CEM PD508 Multiplexer/S&H 16 x CEM 3387 VCA / VCF (analog! 24 db lowpass & 12db highpass filter and panning) also in the prophet3000 16 x SSM 2024 Quad current controlled Class A amplifier with S/N 82dB 2 x Motorola 68000 16 MHz CPU (1 x mainboard, 1 x per 16 voice slaveboard) 2 x Waldorf custom ASICs.
Microwave microwave 1 8 CEM3387 VCF,VCA,VCP (later models) 8 CEM3389 VCF,VCA,VCP (early models) the revision was app. at the same time as waldorf changed to the Nextel-Housing --> "old" eloxiertes Gehäuse (housing) = 3389 - Nextel-Gehäuse (housing) = 3387 it's know exactly know if there are also a small amount of old/new CEMs in the vice versa housings, but it is most likely the same date.. ;) microwave 1 opened
pulse / afb / Q+ filterboard: custom waldorf chips
the Q naked (non analogue version) BOARD - eine nackte nichtanaloge Kuh PLATINE ;-) (thanks to midicase.com! for the pic of the board!)
waldorf q boardwaldorf q+
Waldorf MW2/XT --- Motorola 56303 microwave xt _____________________________________
Yamaha
