*** BREAKING NEWS ***
Ein verrückter Montage-User erzählt im Yamaha Synth Forum, was passiert, wenn man mit einem MIDI-DIN-Kabel die MIDI-OUT-Buchse des Montage mit der MIDI-IN-Buchse des Montage verbindet…
Thought I’d try this out. I ran a MIDI cable from the „out“ to the „in“ on the back of the Montage. I set up a 16 part performance. I had to assign a MIDI channel „out“ to play the MIDI channel „in“ for channels 9 thru 16. I had to turn on the MIDI zones for each and assigned channel 1 „out“ to channel 9 „in“ for example. This could make for a pretty enormous sound no doubt. Parts 1 – 8 were still under keyboard control as usual. While in the mixer I could mute any part(s) I wanted to control this massive sound. Here’s a photo and you can see all of the levels are hot.
https://www.yamahasynth.com/index.php?option=com_easydiscuss&view=post&id=9059&Itemid=851
