SynthiLeaks: Roland JD-Xi Synthesizer (NAMM 2015) + Elka is back?
Leaks from somewhere –
Beside the bigger brother, the JD XA Synth with hybrid technology – here’s a smaller version..
the Mini-Key Synth labelled JDXi
$499 which is quite fair for what you get -> 530€
UPDATE: here’s a screenshot of one of the sound creators (Scherer) @ forum you explained this is a PART of all – which you can still edit on the JD-Xi – he did this CTRL set to create sounds more easily – note the upper part must be seen trippled! – so it is a lot you can do – all on the box
Here’s a quick rundown of most of the features for those who don’t have time …
via: Forum • Roland JD-Xi Synthesizer looks a bit like a Microkorg competitor that sort of may be a System1 remodelling or something new or something polyphonic for everyone since it has enough memory buttons and small size it seems it is a bit smaller in functionality and maybe has one envelope to offer – sort of new SH101 in a Microkorg shape but with SH sound? would’nt be that bad, huh? no – it is a mixture – an analog synth with digital aid of 2 oscs – so it’s 3 OSC synth plus drums.
UPDATE / TECH SPECS
- 4 Sources: 2 digital (PCM) ones, one analog and drums (TR808/909), subosc
- it IS real analog – or better it is hybrid. it is ONE OSC-FILTER Section analog – the rest is digital – nice one!
- has PWM
- drum sounds can be filtered
- digital distortion etc – FX of course
- 1 knob for ADSR – but also ADSR individually in the menu
- LFO has multiple targets – 3 directly on the knobs, rest via menu
- MIDI channels are 10 drum, 1/2/3 is for the other layers
- analog: 24dB/oct – digital: classic multimode with peaking etc.
- 128 voices digital + 1 voice analog osc with analog filter
- TR step Sequencer and Drum Sounds (wow!) – it’s sampled drums so it doesn’t cannibalise the TR8) with 4 tracks, 64 steps – chains can be done quickly! this is a performance thing!
-> I do not really need more „analog“ stuff but I hope Roland and others to do more performance sequencers into their synths that are capable of more than 16 or 64 steps – seems they did it! and that’s why one should buy it – just for them to let them know – they are right! - USB / USB-MIDI
- Vocoder built-in
- UPDATE: digital and analog are a different channel – so no interaction between both – could be cool. – so no layers or so but rec’ing 4 tracks and layer that way of course.
- seq input: step-like just hit the note / drumsound and press step button to have melodies / notes assigned.
- 512 sequence patterns
- sequence patterns chains availables – easy to create (one button – saved)
- CC / automation can be recorded
- USB / MIDI
sound:
filter:
more
we’ll know better on 22.th this month (at NAMM)..
does it look like a Microphone for a built in Vocoder (VT3) on the left? so – looks a lot like Roland wants to be back in the good sounding world of really (being) used synths in 2015…
Update (NAMM):
Roland bringt einen kleinen sicher digitalen Synth, aber ob mit System1-Sound und Technologie oder anders? Nicht zu erkennen, aber wäre sehr sehr sinnvoll – vielleicht mit 6-8 Stimmen?
Aber Roland macht nichts analog, passt nicht zu deren Grundhaltung – aber sie machen immer etwas neu und orientieren sich gelegentlich auch an sich selbst – Siehe Aira / System 1 etc.
–> mehr/aktuell @ Forum: Namm 2015, wachsender Synth-Markt
More NAMM: 2015
n ote: a lot of room is up for synths this year – so there could be a lot to come up soon.
more videos Roland JD-Xi Synthesizer
http://youtu.be/HPVDmxh6BNU
another song playing
eg a re-released Elka Synthex.
http://www.attackmagazine.com/features/new-products-namm-2015/2/
http://www.generalmusic.com
or possibly something new under the name of Elka, LEM or GEM.
I hope this prototype has it’s keys enlarged for the final product, although I doubt it. Analog polyphony would be fantastic, but seeing Roland’s track record lately, I would imagine digital analog modeling (or wavetable based on Jupiter, Juno, JX sounds) is the most likely form of synthesis. It looks like it has an awesome step sequencer, though!
I don’t think it will be analog or at least no more than a good emulation of it since they have shown they can do so (system1) but that keyboard was the odd side of it (no dynamics, 2 octaves, not the best) – looks like it has some fun inside and maybe more than that – some1 on my forum had his hands on it – so he might know better, he says it was more than „expected“ in depth – so it sounds like it can to more than it might appear / look like..
[…] it’s that easy this time JD-Xi is something new (non Jp but something Sys 001). – but st… […]
[…] Die ersten Namm Gerüchte von Arturia, Clavia und Vermona, Elka und Casio und einigen […]
[…] SynthiLeaks II pre NAMM 2015 brings us: the MS20M which is a rack or desktop MS20 without keys (seems to be a kit) and a miniature SQ1 analog step sequencer that looks a lot like a nano control but has pots and buttons for simple step sequencing – sync out/in for Volca control with gate/CV […]
[…] Ich habe einige NAMM Infos upgedated, da es jetzt Videos (oder neue Fotos) gibt: Roland JD Xi, Korg Odyssey, Moog […]
[…] synth is the “large” version of the new series that the JD Xi leak looked ahead on – and looks like […]
[…] the JD-Xa and JD-Xi and the very interesting Aira MX Automator/Mix there is also something new for the System 1 […]
[…] 14 Analog MonoSynth Radikal Module (dual filter, eurorack) Doepfer Module / Trigger Sequencer Roland JD Xi + JD Xa – analog and digital crossover synths with TR sequencer inside! Korg Odyssey 3x Casio […]
I hope they add the capability to play user samples and user created patches.
I don’t think it is possible to upload samples in the Xi – this might be a ROMpler – possible on the JD-Xa since it will be the new flagship
[…] keys on the new synths (Korg Odyssey, Roland JD Xi) – so this is very very wide spread – at the Forum there are plenty of those as well […]
[…] I told you around the time of NAMM – Elka will return – and here they are – but they are […]
[…] may be another thing to see at the Musikmesse – cool stuff coming up – and JD Xa and Xi will be shown as […]
[…] System 1m / Roland vs Reon analog Synths (new Aira?), Xi and Xa will be shown the first time […]
