Roland Synthesizer – Menu
ROLAND SYNTHESIZER & Roland DRUMMACHINE
CLICK ON THE DESIRED TIMELINE / SERIES – KLICK AUF DIE GESUCHTE ZEIT/SERIE:
Roland Synth + Drummachines overview..
Roland Synthesizers
Roland History – the Roland SH series
Roland was founded in 1972 by Ikutaro Kakehasi, Japan (prior companies: ace (drum machines and electronic organs and kakehashi musen), first synthesizer: 1972 – mr kakehashis biography is available as a book from robert olsen, sh1000 preset synthesizer with ADSR env and some „unconventional“ parameters, not to confuse with the real preset synth sh2000, Roland SH2 (did I mention this synth sh-2 ? 2VCOs, another 1 subosc, quite typical SH with 2 ENV,
the 1978 built SH-1 was some sort of prototype for a number of SH synths to come in the mid/late 70ies.. well, the sh3, sh5 and system 100 were earlier (1974-76), but the sh1 was more „compact“..
Roland | Roland Synth overview.. |
- Analogue Trigger Roland: 5-15V (20ms min.) – positive gate pulse
find DIN SYNC pins and describtion here:
- DRUMCOMPUTER / DRUM MACHINE SECTION – > TR series / TR909, TR808, TR707, TR606 etc. CR78..
drum machines out trig: 10-15V positive gate pulse find DIN SYNC pins and describtion in this SECTION!
- see Roland Vocoders..
modular pin connections and DIN SYNC 5 pole DIN:
modular pins | modular pins cont’ed | DIN SYNC (DRUMCOMPUTER , TR series) | |
Pin 1 power/15V- Pin 2 power/15V+ Pin 3 gate Pin 4 trigger Pin 5 power/GROUND Pin 6 your CV |
Pin 1 power/15V+ Pin 2 gate Pin 3 N/A Pin 4 LED pos. Pin 5 trigger Pin 6 power/15V- Pin 7 power/GROUND Pin 8 CV Pin 9 LED GROUND |
— | DIN SYNC: same as tb303, TR606, TR707 (also with midi) pins on the roland DIN sync: from left to right: 3 tempo clock 5 fill in 2 ground (middle pin!) 4 reset & start 1 start/stop midi pins? check this |
for linking DIN 6pin | also DIN.. | the DIN SYNC Interface PINS |
THE ROLAND SYNTHESIZERS ARE (click the menu above):
- SH Series
SH101 / test / audio / MC202 / CMU810 , SH series: (sh1,sh2,sh7,sh5,sh3a, sh101)
-SH5 / schematic / tricks /audiotrack , faster LFOs for system 100 & SH5 , Roland SH5 only track + Roland SH7
- JUPITER SERIES: Jupiter 6, Jupiter 8, Promars MRS2 / Jupiter 4
- Juno 6 – 60 -106 , Alpha Juno 1 / 2 mks 50 series / pg300
- Modular System 100m / System 700, modular series
System 100 the smaller semi modular.. - Groovebox TB303, mc303, mc505 , mc307, sp606, MC909 groovebox SP/MC/TB series: here
- DRUMCOMPUTER: Ace, TR 808, TR 909 , CR78 etc..
- JX Series: JX8P / JX3P / super JX / JX10 – (–>JX8P test deutsch/german)
- PG programmer , and MKS racks / expanders / cmu800
Roland Digital Synthesizer
- Roland DIGTAL Rompler / Sampler Series JV, JD, LA, D Series, Fantom etc..
Roland JD800 / JD990 – JV series newer models JD,XV, JV 1080 – 5080 etc..
D50 / LA-Synthesis – Roland Samplers S770, S750, S760, W30 workstation
Fantom , Workstations : XP and RS series
- VSynth / Vsynth XT Rack – variphrase synthesizer! / VP9000 variphrase sampler
VariOS (compare variOS , VP9000 , v-synth)
- Controller: d-Beam Controller
- Virtuell Analog Synthesizer – JP8000 / jp8080 /SH32 deutsche info sh32/jp8000 hier
- EXTERNAL LINKS
deutsch/german: Roland hat eine übersicht (kommentare nicht zu ernst nehmen, ansonsten sehr liebevoll)
zur Roland Synthesizer Zeitleiste / Roland synthesizers timeline
- (roland)
- manuals @ roland
- btw: Roland olso does/did FX units like the nice SRV2000
nice to edit by up/down buttons and easy to use display..
<– click to enrlage SRV2000
Roland Roland Synth + Drummachines overview..
Comments are closed.
