Roland Programmer, MKS-Series, JX-Series
Roland Analog Synthesizer
– the Roland JX Synthesizer Series
-Roland Programmer mpg + mks racks
programmers for D50, MKS70/JX10,JX8P, Alpha Juno/MKS50, JX3P/ MKS30
ROLAND SYNTHESIZER | images (click the pic to enlarge it – if available) |
Roland JX8P / JX3P / JX10 Synthesizer: made in 1984 Roland JX8P deutscher detail – test hier!!..the digital era began – the 2 DCO synth also have crossmod , both need programmers to be programmed by sliders, but you still can edit them on the box, but the digital way using one edit slider and type in the parameter number (see the parameter list below) .. made synthesizers cheaper, yes.. the jx8p’s resonance can not reach self resonating filters, but sync and crossmod is possible, one lfo, the jx8p had velocity and aftertouch response and also negative env mod (choose one of 2 ENVs or one LFO – about 30hz max speed) VCA: additional „gate“ envelope to help make nicer sync or filter mods.. think „pseudo 3 ENV“ here. chrous there,too. the super jx (jx10) was exactly a doubled jx8p (12 voices!) – it’s ROM can be changed for SysEx upgrade by Colin Frasers „hack“. jx8p and mks70 (the racked jx10) can be controlled by the pg800 programmer. the jx3p needs the pg200 (mks30 is the expander version of the jx3p)The JX10 opened looks like this (Colin Fraser’s Site again) sync modes jx8p/jx10: the sync and xmod is quite unusual on these synths: use crossmod to get what you expect : quite FM-type of mod (dco2 mods DCO1), sync up DCOs with sync2 also tracks to keyboard, sync1 is also sync+crossmod! not enough more sounds mks70 (double jx8p / single jx10 as rack) – presets only.. wanring: preset aren’t the best way to check for sounds.. but.. |
JX3P![]() image jx3p thanks to jörgthe MKS30 as rack (by myself).. ![]() ![]() ![]() see the jx8p parameters?: klick this: ![]() larger? grösser? .. to see the parameters.. audio JX8P demos: |
Here is a Rack full of MKS ..on top: svc-350 vocoder.. no mks ;) mks-30, a racked jx3p ![]() in the rack: pg-80 programmer and mks-80 (racked jupiter 8)MKS70 – JX10 rack Version.. ![]() mks-50 – racked alpha junoand the sampler mks-10 (racked s10, simple sampler) and a roland remote keyboard on the left.. read on for more on the mks synths and programmers.. |
The Roland MKS Racks![]() |
Roland Programmer + MKS Rack versions Roland offered knobs for their rack synthesizers and some key versions very early!Rack Versions and Programmer Names..PROGRAMMERS and RACK modules – PG and MKS series .. what programmer and what mks is what synth?:
AUDIODEMO some audio by myself on the mks-80 or better go here: roland manuals |
RACKED JUPITER8 and alpha juno -> MKS80 and MKS50 ![]() click to enlarge. mks80 is quite large in a rack and is the one of those rare synth with XLR outs, see the extra PG? (click pic!) – 2 outs for upper and lower section… ![]() ![]() ![]() PG80 and mks80 (racked Jupiter 6 / 8 „something“..) ![]()
mks80 vs. mks80: |
MKS80 – and Programmer PG300 board.. ![]() |
Programmer PG-300![]() |
<– Roland MKS Rack.
BACK TO Roland MENU / zurück zum Roland Menü..
Roland | Roland Synth + Drummachines overview.. |
