Moog Little Phatty upgrades to OS v3.1
Phatty Firmware Update OS v3.1. it’s free.
also Moog Music got a new website which is much more optical/visually styled..
Volume Velocity Sensitivity: The ability to map note velocity to output volume with fifteen adjustable levels of sensitivity saved per preset. [Tribute Edition hardware does not currently support this feature]
Legato Glide: Automatically engage the pitch glide between legato notes. Non-overlapping notes snap instantly to a new pitch. The user is able to play or sequence dynamic bends and slides mixed with cleanly-articulated notes.
LFO Reset: The ability to reset the LFO cycle at the start of each note. Two LFO trigger modes provide dynamic new modulation possibilities.
Sustain/Hold Mode: A sustain pedal or control voltage plugged into the CV GATE input jack can now be used to send MIDI Sustain on/off, and to polyphonically sustain MIDI notes from the Phatty keyboard.
14-bit MIDI: All Phatty synths can now send and receive high-resolution 14-bit MIDI messages for critical voltage-controlled parameters.
MIDI Output Filtering: New options control which MIDI CC messages are sent from the Phatty, for maximum compatibility with external gear.
Expanded MIDI Clock sync options: 22 clock divisions including triplet values for both LFO and Arpeggiator MIDI sync. Clock divisions range from 32nd triplets up to 4 bars.
Improvements to Arpeggiator:
· Global Arp Setup menu: Set important arpeggiator parameters at a global level. Arpeggiator also remains active when presets are changed.
· Gate Length: Adjust the arpeggiator note length from 50% to greater than 100% (overlapping), for a range of new sonic textures.
· Arp Clock Send: Arpeggiator can now send MIDI Clock, MIDI Start and Stop messages, allowing you to synchronize other gear to the Phatty internal clock.
Improvements to Polyphonic Mode:
New polyphonic note-allocation scheme: Uses a “round-robin” algorithm to share notes across multiple Phatty synths in a natural and very playable way.
Polyphonic arpeggiation: Multiple ways to use the Arpeggiator across a poly chain of Phatty synths, from tight integration to completely freeform.
Related posts
