Synth
Modal 008 Analogue Synth (8 voice) with Xpander-Style Filters (with Phase/Allpass)
the original info from Modal
(so it has still some super-words in it) ;)
Modal 008 (built 2015) – Analog Synthesizer
provides eight discrete voices of polyphony with an uncompromising analogue
architecture utilising the highest grade components throughout
Modal 008 synthesizer
Two 100% analogue VCO’s per voice
with two sub oscillators, providing sawtooth, triangle, square
with PWM and noise.
note those filters are a bit like the Oberheim Matrix12 synthesizer
 Oberheim Matrix 12 (built 1985) – Analog Synthesizer
that allows combinations of filters including phase shifting / all pass filters that really sound great for pads and stuff.
OSCS:
Each of the waveforms can be blended together to provide
completely new complex wave shapes Innovative and
extremely flexible 16 multi-mode filter, consisting of traditional modes such as low-pass, band-pass and
high-pass as well as more unusual notch, phase and combination modes.
Filter overdrive enables the sound to be driven to sonic extremes A range of classic analogue polysynth features such as oscillator and filter FM bringing amazing sonic power
Two LFO’s, both capable of reaching audio rates with multiple wave
shapes and midi sync
11 modulation sources with unlimited destinations. Each destination can be set it’s own unique depth, a super smooth sample rate of 10kHz and all accessible from the front panel – no menu diving 008 features a range of sequencing options
– a built in 2 Track, 12 row, 32 step sequencer with
16 dedicated step time editing knobs on the front panel and MIDI sync capabilities. Sequences can also be transposed dynamically while running
A very highly featured arpeggiator with a wide range of different modes, including ‘hold’ mode, enabling arpeggiator-based sequences to be created The Modal Electronics Animator, which enables any control parameter on the 008 to be sequenced, enabling very complex filter transisitions, wave form changes and
modulation matrix changes to be sequenced Ethernet port to connect your 008 to your network and enable updates via the internet (no more midi sysex dumps) and access to the Modal Electronics cloud features
Two part multi-timbral (bi timbral) allowing splits across the keyboard or stacks to create amazingly complex sounds Superb UI, a great departure from the norm of synthesisers, featuring a very high quality 4.3? screen with wide viewing angle, display is context sensitive where the control parameters of any control knob that is touched by the user, is immediately displayed Eight
‘quick
recall banks’ are accessible directly from the front panel, enabling performing musicians to get rid of their set sheets and build set lists of presets, sequences and animations, all quickly accessible from dedicated front panel buttons. Up to ten banks of quick recalls can be created, making live performance a doddle Ultra fast (1ms) VCF and VCA envelope generators. VCF-EG is one of the 11 modulation sources that can be freely assigned to any parameter by it’s own unique amount Four Key Modes – Polyphonic, Monophonic, Unison and Stack Very high quality construction, uses a premium FATAR semi-weighted five octave key mechanism with aftertouch All voice control parameters are accessible from a well designed and intuitive front panel, that follows a traditional synthesiser work flow Combined XLR/TRS sockets for balanced / unbalanced outputs.
Further,
each of the eight outputs can be brought out individually via a dedicated d-sub socket. Optional Digital Output board providing multi voice outputs over USB (Class Compliant) with FX available Q2 2015. Two audio inputs enabling audio processing from the VCF onwards plus external MIDI in and out XY joystick and
Sustain and Expression pedal inputs for performance controls – any control parameter can be assigned to any joystick axis (X+, X-, Y+, Y-) by pressing the dedicated front panel selector button
Forum; Neuer Analoger von Modal: Modal 008 / 002R Rack
Related posts
2 Thoughts to “Modal 008 Analogue Synth (8 voice) with Xpander-Style Filters (with Phase/Allpass)”
  1. […] Modal has a 12 voice polyphonic rack -and also a 3 octave 8voice version called the 008!. […]
  2. […] as a Module:Oscs and Filters from the 002 and 008 anda MIDI CV […]
Comments are closed.
