Korg LittleBits Synth Kit – Modular Toy
Korg did it again, a package of little „modules“ to be attached and so to say „patched“ together. will be limited at 160€ or was it $? well.. have fun like this
just have a look: the Lego Modular Synth – small parts that allows „playing“ to DIY for and to have fun (again „fun“ – must be something like.. true?).
Diskussion im Forum • [Korg] LittleBits Synth Kit.
the info text is this: Electronic work gadgets littleBits are looking for there, and collaboration Korg electronic musical instrument manufacturer for beginners. I want to explore the relationship of technology and music, towards all those who have a hobby of music, we have developed a new kit „littleBits Synth Kit“ and engineers, seeking musicians and a new sound. Synth Kit is a kit to be assembled scalable and easily customizable „own“ a modular synthesizer at home. To Bjork from The Beatles, top artists have been using the analog synthesizer with the aim sound more elaborate, music making innovative than ever before. it is possible to without the need for a knowledge of music and electronic circuit design and assemble easily, (signal generator, modifier, modulator, controller) the circuit of the synthesizer, littleBits Synth Kit can be also utilized, such as live sound, recording and It is a kit was not so far. Let’s make the original synthesizer using a combination of modules. A set of modules Bits twelve, Synth Kit allows you to assemble an analog modular synthesizer by connecting a small magnet to each module. In addition, It is the one that was developed based on a circuit that was used in the famous analog synthesizers Korg part of the module. The type of module of Synth Kit, there are (× 2), filter, envelope, delay, keyboard, micro-sequencer, mix, split, random, synth speaker power (power supply module), oscillator. If there is littleBits Synth Kit, you will be able to build up a modular synthesizer that can be modified any number of times. Moreover, there is a scalable littleBits system, building a synthesizer more powerful by combining Synth Kit can include multiple. Also, the system making it by incorporating littleBits other modules, using the mechanical light or is freedom. Of course, cumbersome wiring and soldering, programming is not required at all. Project booklet that describes the procedure of circuit assembly. Project booklet which recorded the fabrication procedure of work fun example of 10 kinds comes with Synth Kit. According to the booklet, you can also more fun, to work the interface rich in ideas by combining the material with the familiar, such as plastic that was output tape and cardboard, a 3D printer to Bits module. It is a tool, such as the following: Percussion Party: Assemble the circuit using a combination of modules of seven, let’s dance to the rhythm! Set the rhythm, by adjusting the tone, you can create an intense beat to beat from a loose eye to control the envelope. Let’s make the shoulder synth your own by using the familiar material and modules of nine: shoulder keyboard! It with a decoration, if you attach a strap and stand on the stage at any time! Make a turntable with a synth in a combination of eight modules: synth spin table! Make a turntable with a straw and paper plate, let’s play the synth as DJ! I have also included work example and performance, tuning, play song, Spooky sound, metal music, synth band, professional-looking in addition to this. In addition I have also included application of circuit design, such as delay pitch sweep, white noise, KEY PLAYER, sequencer control,-Frequency modulation, random-voltage, noise filtering, and echo. comments from littleBits / KORG. is the founder and CEO of littleBits, Aya Buderu MIT (Massachusetts Institute of Technology) Media Lab graduate, TED is a (Technology Entertainment Design) Senior researcher (Ayah Bdeir) said the leader in „electronic musical instrument industry It has said. „are very pleased that we can be able to work with a Korg, thus announcing the littleBits Synth Kit. Subsequently, the ultimate goal of „Our littleBits, is to break down to the major parts unit technology, everyone is so Ayatsureru freely the power of electronics. This new kit, analog so far- It is easy to use most of the modular synthesizer, it also. can say that it is one of the most high quality, this kit is designed to make Yobiokose person of any age is hidden in in a „rock star soul“ I have. “
where are those parts from? the MS20..well, the MS20 has no sequencer but the kit has one plus a keyboard in very mini format.
The message from Korg is as follows. „With this new littleBits Synth Kit, you can explore the synthesizer sounds and a whole new music fan, in a unique way. Developed a Synth Kit with littleBits, we Korg, this to all music fans not only Korg fan I look forward to the future.’ll be able to convey the fun. “ > KORG INC. Specification Bits of module 12 Power Modules Blue Power Connect the cable and 9V battery included, and supplies power to the entire modular. Input module of Pink (9) Oscillator × 2. It is a module that creates a sound that is Omoto. I can adjust the tune and pitch. I can also switching waveform of square / saw. Random There is a random voltage mode to output noise mode to output white noise, a random signal voltage. Keyboard You can play the melody on the switch of thirteen one octave. I can also switch the octave. Micro Sequencer I created a melody consecutive. I will output in order to step-by-step voltage, which is determined by the position of the four knobs. Envelope You can add a volume change in the sound, to create a sound that changes the volume slowly as sax sound and strong attack as piano. I can adjust the decay and attack. Filter I will give a significant change in the sound. I can adjust the peak and cutoff. I adopt the filter circuit of MS-20 late type. Delay I realize the echo effect. I can adjust the feedback and time. Mix It prints the added together into one two signals. I can also adjust the volume of each input. Wire module of Orange Split I can branch into two signal flow. Output module of Green Synth Speaker You can adjust volume. I is equipped with the output jack. ※ troublesome wiring and soldering is not required for the assembly of modules. ※ It is also possible to design a new circuit based on these circuits circuit of each module is an open source. Project booklet I comes with the project booklet of 36 pages that describe the steps of the circuit assembly is kind to beginners. I have also recorded the history of the synthesizer and commentary on sound scientific. I record engineer of littleBits, a modular construction example by designer. Contents of 10 kinds Tuning, Play a Song, Spooky Sounds, Percussion Party, Metal Music, Synth Band, Synthesizer with the Works, Perform Like a Pro, Keytar, of Synth Spin Table. I have recorded the circuit ideas guiding examples of modular construction. Contents of white noise, key player, sequencer control, frequency modulation, shape your sounds, random voltage, filtering noise, echo and delay. Accessories (For connection of the power module and battery) 9V battery, power cable Package container that can be used to play for tray Booklet of 30 pages or more“
[…] See on http://www.sequencer.de […]
