Engineers@work – Trigger to MIDI Interface under 50€
Engineers@work.got a semi-DIY Interface out to set your drum module or anything that has any trigger inputs somewhere inside to be set to life. since it’s only 42,50€ this is a no brainer at almost no risk.
Features:
  • Has Midi input and midi thru connectors (included seperately)
  • Has 24 trigger outputs ( 5 volt positive puls, selectable 1ms, 10ms per pulse or note on/off)
  • Has 1 master trigger output ( triggers always when 1 of the 24 outputs are triggered)
  • Triggers notes 36 to 59 (c2 to b3)
When you play a note , the corresponding trigger output will genarate a pulse of 1ms or 10ms,
or will be high as long as the note is on (set with dipswitch) Ideal for your D.I.Y. synthesizer / drumcomputer project.
  • Can be set from channel 1 to 16 with a dipswitch
  • 1ms ,10ms or note on/off selectable with jumper.
  • Trigger outputs are available on 2 14pin headers.
  • Can be set to midi monitor mode.
via Forum Acidlab Module: 808 und 303
Related posts
