Emu – Eµ – E-Mu – Menu
EMU = E-Mu = Eµ Sampler + Synthesizer:
EMu | Emu Synth overview / überblick.. | |
Emulator Series IV![]() EIV samples scroll down – incl convolving algorithm demo.. Proteus 2000 with Z-plane filters..
Proteus 2500 with „groovebox“ style sequencer |
EMU Drumulator 12 Bit Drumcomputer used by Front242 on „no comment“ or Depeche Mode on „work hard“ (a b-side)
it has 12 Drumsounds and 4 Pads. Of course all sounds can be used in a pattern but you need to re-assign the pads, thats very easy: hold the pad and press the desired drumsound. E-mu is the name that came from E-µ (mu / mü) the model shown has a retrofitted roland din-sync, it’s not standard ;) but the individual outs are, some are cinch some are standard mono jacks.. i have no idea why they used cinch ;) the sounds: to all who never listened to the „no comment“ CD by Front 242 or DAF „fünfzehn neue DAF lieder“: quite hard and ebm-like but also with punch from „below“.. of course the drumulator name came from the legandary emulator series, they did the Emulator 1, II , III, IV .. possibly the best known samplers ever.. E-mu Drumulator..+ SP1200/SP12 – for your own samples.. |
![]() ![]() ![]() modified: the roland DIN sync here: ![]() |
modular system..e-mu did some of the first digital modules , some innovation in it.. more on this soon..
they also did a very innovative modular system, the e-mu modular they did one of the first polyphonic keyboard and digital sequencers and lots of innovative technologies at THAT time.. |
E-Mu Modular![]() |
Emu software sampler?
Emulator Ultra software/remote software. |
EMU is now owned by sound card manufactor creative labs, so emulator and proteus are PC only solutions now, no mac version, so not of too much importance, now, huh? .. not that bad,, since it incorparates the old EIV structure .. more or less..the older info / die alte deutsche info:![]() software ultra serie leider wird der softare-„Emulator IV“ nur einen 24dB LPF bekommen, keine z-plane filter.. (angeblich wegen des h-chip,der die filter berechnet) nunja: selber schuld.. dann verkauft NI eben mehr „kontakt“ sampler – also nur remote mit allen filtermodellen! Als interessantestes produkt entdeckten wir den emulator soft als betaversion. Der lässt sich als vst-plugin oder auch standalone verwenden. Basierend auf dem standard e4. Ein solcher lässt sich auch mit dem emu soft fernsteuern (dieser kann dann als grafikeditor verwendet werden und soundmanagerfunktionen übernehmen im moment existiert nur die pc-version, die mac-version soll aber bald folgen. |
(deutsch/german) | Emulator IV / zplane audio demos.. | |
EMU SAMPLES .. | ![]() vergleich sampling /wavetables / aus meinem synthdiplom audio von 1993/97 Track 26: „Micky-Maus Effekt“ a: verschiedene Tonhöhen aus dem Microwave b: dito, gesamplet mit dem Emulator IV c: dito, gesamplet mit dem ASR-10 – Track 27: dito, mit anderem Wavetable Abhilfe bei den Samplern wäre: mehrere Samples (Multisample) benutzen! – Hi End Sampling: Track 32: Sounds aus meim damaligen Emulator IV – diese kann man mit dem digitalen Algorithmus „transform multiplication“ miteinander „verschmurgeln“ lassen, faktisch ein „morphing“ zweier klänge! Hierzu wurden verwendet: a: Bremsenquietschen & Streicher b: meine Stimme & chin. Becken / Gongs Mit den mehrpoligen „Z-plane“-Filtern wurden diese Sounds noch etwas verfeinert. – Track 02: Sampling a: scheinbar „endloser“ Klang aus dem Emulator IV (geloopt) b: einige geänderte Schlagzeugsamples (Emulator IV) mit anschließendem gelooptem „Metallsample“ (Ensoniq ASR-10). Die Looplänge wird moduliert (verkürzt), bis sie gleich „0“ ist. c: ein bearbeitetes Sample mit subtraktiver (Bandpaß-) Synthesizernachbearbeitung (Emulator IV) |
.. SAMPLER und Emulatoren.. | HARDWARE SAMPLER für KLANGdesigner..
SAMPLER in hardware ,sampler in synthesizern? grooveboxen? sampler in sequencern? audiostream als samplerersatz? hier eine sicht aus dem ausgehenden jahrtausend und die zukunft der reinen hardwaresampler— imo ist ein GUTER sampler, wenn er gute klangqualität hat, eine vernünftige FX und filtersektion. zusammengenommen eine gute klangmaschine. beispiele willst du sicher: die emulator serie ab II und emax sind zB gute filter-monster, die FX sektion ist eher mässig (E IV),aber dafürf haben die neueren (E IV,esi4000,E64 etc..) spannende filter und man kann ne menge damit anstellen. mehr über Sampler |
find more on the emulator archive sites
