Collecting Features for the Waldorf XT OS 3.0
feel free to post here. (I’ve pushed this post from 21.11.2006 back up here)
note: comb filters are not possible on the XT due to the DSP Ram, also the Code Space is not that large..
beside bugfixing, the ppg filter (which I do not find that desirable compared to other ideas..) and filling up the reserved wavetables?
any Idea..
__
Ein paar Ideen zum MicroWave XT OS 3.0?
Forum: Waldorf Microwave XT OS 3.0
what is / was ist ein XT?: Waldorf MicrowaveXTk, MicrowaveXT
Microwave XT Microwave XT synthesizer
here are some listed so far:
•being able to switch of the bass boost on the Xt..
•setting the ringmod points to other than just the OSC outs (can do a lot post filter btw)
•fm modewithout affecting note pitch (means DC filter)
•filter bypass – maybe also saves DSP powrer
•upper wavetables
•bit/resol. cruncher modable in filter 2.. with simple static filter for no-nice frequencies – other filter models that offer nice combinations of digital dirt and filtering.. in that case we need filter 2, in other cases I could imagine using the power for other things..
• wave editor and wt editor on the box, can be simple like using the env knpobs 1-8 and the mode switch for editing the additive waves and a simple list of numbers (waves) for the WTs, should be easy and should not use too much code ..
•sequencer via env-knobs – switch to 9-16 via the env mode button.. easy and usefull simple stepper..
-> no comb because needs DSP Ram which is not available, also code space is low..
more?..
Related posts
Comments are closed.
