Arturia goes Hardware
https://www.sequencer.de/syns/arturia/Origin.html
Origin Synthesizer by Arturia
Moog V, ARP V oder CS80, Prophet V als Hardware? sieht so aus..
Arturia also plans a Jupiter 8V or better: looks it is already there with Sequencer..
Arturia wird auch eine emulation des Jupiter 8V veröffentlichen.. inkl Sequencer (was das Original bekanntlich nicht hat)
Arturia goes the Hardware way incl all current Synth plugins as Hardware.
- More than 500 presets created by talented musicians and synthesizer specialists
- Up to 32 voices of polyphony for a typical patch
- Create your own patch or use an existing audio structures: an Origin patch made by connecting independent modules, or the minimoog V, the ARP 2600, the CS-80, the Moog Modular.
- Superb audio quality with TAE® engine. 24 bits/96 kHz supported.
- Compatibility with most of the presets from the Arturia Classic virtual Analog synthesizers.
- Origin lets you open dedicated software on your Mac and PC and use it as an AU or VST plug-in. All the sounds are calculated on the machine while you work on your computer as you would do with a native application.
- Analog: 2 audio ins, 10 audio outs. Digital: SPDIF out, USB 2.0
- Large selection of effects: Phaser, Chorus, Delay, FX Reverbs, Distortion, Param Eq, Compressor, Bitcrusher
- 16/32 step sequencer
- Innovative Macro, Advanced LFO, modulation modes, Advanced Joystick modes.
- MIDI : In, Out, Thru or USB 2
