Alesis Synthesizer
Alesis + Alesis Andromeda ( A6 ) Analog Synthesizer
Drum Machine | Alesis Micron | Alesis Ion | |
![]() the HR16.. 80ies 16bit |
Remote Keyboards X25 + X49 |
Alesis Fusion Synth |
–Masterlink
test in german |
A6 Alesis Andromeda
(click here!) ANDROMEDA – SPECIAL SECTION..
Alesis | Alesis Synth overview / überblick.. |
Tricks & infos site.. phatter, fuller, wider.. ANDROMEDA A6 real analog Synthesizer THE ALESIS ANDROMEDA A6 TRICKS – INFO – PICTURES.. go here (section has moved to the database..) |
THE ALESIS ION / MICRON HAS A QUITE „ANDROMEDA’ish“ structure but sounds very different.. |
alesis micron (+ compare ion / micron) same as ion but with nice kind of one-finger-sequencer with programming on the display.. it’s a small synth but it works..more alesis micron.. the structure is 3 OSCs and 2 fast LFOs (1khz), modmatrx and 2 filters with some „emulations“ of filter types: jupiter, moog, oberheim and formant filter types are available. well, it’s still a VA and so you should not expect it to replace a moog or jupiter.. but it isn’t a bad sound!!! it has 8 voices. there is an ARP’er (ion) and a little sequencer (micron) on board, more for the rhythmic part of your life.. but it is there! some sort of motion recording for controllers is there ,too. |
![]() the structure is very different from a microkorg, but it may be theeeee competitor for it.. well, the micron has the more powerful engine and double voices and multimode… (4 slots).. well, I’d say it is quicker on a microkorg to program it and to find the parameters on stage.. but the micron has a full size keyboard and the more flexible sound engine.. of course there is OSC sync and FM aboard and also those 20 filter types.. audio inputs are available in both.. |
ALESIS FUSION 6 OP FM Synthesiizer with Physical models of wind instruments and HD Recording and kind of „extended“ micron / ion VA Synth.. it has 8 ENVs and 8 LFOs (!!!!) .. the envs are multi stage. more Alesis Fusion Synth.. |
ALESIS X25 and X49 – remote control keyboard with dimensional sensor has the airsynth sensor!! remote keyboard with audio interface in one .. 2 oct remote. not a bad idea.. it’s quite comaprable to the d-beam by Roland but has 3 controllers / directions that influence it.. rolands d-beams are more „one“ dimension per beam (they have 2 on most beam-equipped gear like the vsynth..).. there’s also a larger version of it in black: |
The Alesis DrumMachine HR16 (right) from the mid 80ies with 16bit Drum Samples (a bit more than 40 Samples, the B Version was even more powerful „rockier“ and used by the first us bands on the industrial side of life like mentallo and the fixer etc.. |
more to come..
